Hello
I'm currently running Audacity 2.0.6 on Windows7.
I have a newbie question: I need to extract several parts from an audio file, add some fade out/fade in to mash them up, and save the whole thing as an audio file.
What is the right way to do this?
Is there a way to 1) mark several parts with start/end points, 2) tell Audacity to remove the rest that I don't need, 3) add some fade out/in for each segment, and 4) save the whole thing as an audio file?
Thank you.
Before I spend more time reading, I forgot to say that I need to 1) select multiple parts of a track because I wrote down the start-end timestamps for each, and 2) delete the useless audio between them. Next, I'll have to add some fade in/outs before exporting the whole thing.
Currently, if I doctor the first part, all the subsequent timestamps are wrong so I have to compute where the next parts are
Do you confirm that Audacity supports this today?
http://wiki.audacityteam.org/wiki/Select_multiple_label_regions_and_invert_selection -
Found a work-around:
- Launch a second instance of Audacity
- In the first instance, create regions for each segment you want to keep
- For each region: Select it by clicking on its label in the Label Track, select Edit > Copy, switch to the other instance of Audacity, select Edit > Paste
Maybe there's a faster way, but it does the job.
Thank you. -
If the audio happens to be MP3 you can do all that without re-encoding using MP3Directcut.
If it's not MP3, feel free to ignore this post.
Joining multiple segments from VHS captures of the same tape
By premiumcapture in forum EditingReplies: 2Last Post: 5th Apr 2015, 12:12 -
Newbie: Need help removing audio/subs from multiple videos mkvmerge
By haloboyvash in forum Newbie / General discussionsReplies: 9Last Post: 11th Jan 2015, 14:20 -
How to rip multiple audio tracks and multiple subtitles into a MP4 file
By Jakob Olsen in forum DVD RippingReplies: 6Last Post: 17th Jan 2014, 12:32 -
[Help] Extract Audio from one file and merge it to another file
By vampelle in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2012, 13:40 -
Extract Audio from RM File without Convert it
By Bruno AUgusto in forum AudioReplies: 7Last Post: 13th Nov 2011, 08:48
